EGR removal question.
Walaboom
Car: 240sx
Hello guys, I have a simple question regarding to EGR removal. First of all I removed this (Picture1). and there are two small hoses connects to the red circle in picture 2.
Should I remove the device I circled in picture 2 as well? What kind of problem will I run into if i remove that device. Also, is there any hoses I need to block to prevent air leaking?
Thanks for your help
MarkEmark
Car: fully-built '95 240sx KA-T
The second disk is called the EGRC-BPT valve. It works in conjunction with the EGR valve, so it's serving no purpose now. I have mine removed right now (still have the EGR crap installed), and the car runs fine.
Definitely remove it, and cap the vacuum line that comes from the back of the intake manifold toward the firewall that connects to this valve, otherwise it will leak out of that line with the manifold is pressurized.
I'm curious too....did you do this with the engine in or out of the car, and with the manifold on or off? Looks like you did it with the mani installed and the engine in...how the hell did you get that third bolt for the EGR valve?
Walaboom
Car: 240sx
Thanks for the reply. When you said cap the vacuum line that comes from the back of the intake manifold toward the firewall that connects to this valve, I assume there is more valves under the BPT that I didn't see, correct?
Yes, I did remove this damn thing with engine in and manifold on...... took me a good 2 hours to remove the last bolt right under the upper intake manifold.I have skinny arms, I managed to sqeeze part of my arm in between the intake manifold from where the TB is, with a long wrench and turn that damn screw 0.1 degree at a time bit by bit.
It is hard, got cut all over my arm after I was done just b/c the space is so limited and some part of intake manifold is really sharp. Definitely the ghetto style.
Florida240sx
I have a trick to get that 3rd bolt LE tme try it on my vert though to make sure it wasn't a fluke.
Structure240sx
took maybe 20min tops on GEO's car with engine in the car and intake manifold on.
get what is called Crows feet. they are like the head of an open end wrench but with a square cut out to put on a socket wrench or extention. works great for things like that since they sit at a 90 degree angle off the extention. i would take a pic if i had them with me
Structure240sx
lrb_2000
Car: '91 Nissan KA-T hatch
or you can do it the easy way and use one of these guys,
nismo521
Car: 1993 Nissan 240SX HB
I used one of these.
fiznat
Car: Grown up :(
I just used these:
PapaSmurf2k3
Site Admin
thats a real picture of foster, he benches like, 4 million pounds... at least
MS180SX
Car: 1989 Hatch- Crushed
1993 Hatch- Sold
2004 350z- wrecked
2005 STI- sold
2003 CBR 954RR- Sold
2005 Chevy Colorado- Sold
1972 Chevy Nova- Gas eater
fiznat wrote:I just used these:
Thats my WEAK ARM..
densmolina
Car: nissan quest
i need help i have a limited budget can any body help me how to remove,clean and replace egr valve and line of 94 nissan quest.egr code failed.please help me
WDRacing
Does the Quest have a KA24DE motor? I don't think so, last I checked it had a VG30E...might wanna check that forum. When you search, pay attention to what forum the thread is in
Welcome to Nico
CityHunt3R
Car: 240SX
HAHAHAH
WDRacing wrote:Does the Quest have a KA24DE motor? I don't think so, last I checked it had a VG30E...might wanna check that forum. When you search, pay attention to what forum the thread is in
Welcome to Nico
HAHAHAHAHA Burned....
well Ive been trying to locate the screws to remove the egr valve. you guys mentioned 3rd screw you meant nut right? the one at the end of the vavle tube connected to the exhuast right?
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
i have all my crapp off since my motors at the shop, whenever i have time i can snap some pictures. i'm still not too sure what to remove. hopefully tomorrow can get some pictures.
CityHunt3R
Car: 240SX
Awsom that would really help cant wait for the pics!!!
