S14Tech »
https://forums.nicoclub.com/s14tech-u72508.html
Sun Aug 19, 2007 3:31 am
So i finished removing egr. Put an ebay plate to plug the hole, plugged that one line heading to the intake (fuel valve thing?), and kind of capped of the exhaust (still leaks). Heres the problem: idles to stall. Been reading up on it and i've looked all over for vacuum leaks, put a resistor on the temp sensor (i'm on an obdII harness), and took a look at the IACV which i think is clear of any obstruction. If i remove the IACV hose where it connects before the throttle body, the engine stays at 1200-1400 rpms, but the second its plugged in to the intake hoses the engine idles to stall. Tried to reset the ecu, both by diconnecting and by turning that dial on the ecm. Why is it doing this? Does it hate me? The engine also threw 5 codes at me: engine runnign lean, IACV malfunction, EGR malfunction, IAT failure, and i think egrc solenoid failure. Looked all over for any harness connector i might have accidentally left disconnected nothing. Help me.
