Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sun Sep 26, 2010 7:11 pm
It's not the AIV, it's called the PAIRC valve. All it does is send air into the exhaust for some reason or another.
I don't know what you mean by "sensor", because all it has is a plug for power to the vacuum solenoid that makes it work... Just un-plug it and rip all that out, go to Nissan and get a bung plug to close up the hole where the pipe goes down to the exhaust. Make sure to buy some nipple caps for any vacuum lines that you remove because of this.
