Hi...I posted this in the online mechanic as well, but I just wanted to see if I get any more info from this forum
...I have been all over this site, and have learned quite a lot about my 240 (89, ka24e). My problem was that I was having a slight shimmy starting around 80 kph (at slight acceleration). I have been reading for several months now and got together with an old buddy that has had some mechanical experience. I told him of my problem and he tried a few things before we finally came up with the possible problem. It was the EGR valve...
We unplugged the hose from the top of the valve, and plugged it.
Viola, no more shimmy at 80kph. He thought that this might possibly mess up a few things once I plugged the hose, but wasn't sure. It just would disable the EGR...? He had this problem with old chryslers or something, but it was at a much lower speed and that's where the idea to do this came from. Anyways, I have read up on every EGR thing on this site but I still have a few questions.
I did the test where I would run the engine at 2k rpm and push the diaphram up on the egr. THe engine did sputter and almost died. It seemed to have a more adverse effect when the engine was at just an idle. From what I gather that means that it is working properly....But what exactly is that hose for that I disconnected? should I also cap the valve where the hose was connected?
The car is also running quite rich. I get crappy milage. I had planned to do a fuel filter change, as well as new O2 sensors to help get a bit more milage, but from what I've read this wouldn't effect milage all that much.
And also, what is this little thing on the hose that's connected to the egr? I was going to take the EGR off and clean it with carb cleaner tomorrow, but I just wanted to know some more info.
And just one more thing...I had an exhaust problem - sounds like a tinny rattle when I accel, and am thinking something either the resonator or cat is pooched. Could a plugged cat cause weird backpressure that would mess up things like running rich and a wonky EGR? My line of thought points toward the exhaust system because the EGR passed the push-n-almost stall test.
What are your thoughts? (anyone...)
Thanks in advance,Chris
