EGR QUESTION
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
okay i searched and read this forum zerothread?id=25585but i still have a small question if i run a tuned ecu with my turbo setup will it still throw a code on? i have a 91 240sx... what if i do it now n/a? will my engine light come on? i have my cat gutted and there is not engine light on for that... mmm... just a question.... thanks!
NateDogg
If you run a tuned ecu, you can program it for no EGR (According to JWT). Also, you should be able to do the same for N/A. The only time you will get an error code is if a sensor is outputting readings which are well out of the normal range (IE no vacuum lines leading to EGR solenoid). Although, most of the time on S13s you wont get a code just because the computer diagnostics are pretty dumb.
1WheelWonder
Car: 1991 Nissan 240sx
I have got a 91 aswell. I have removed my egr, aiv, cat, and charcoal canister with no codes thrown.
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
1WheelWonder wrote:I have got a 91 aswell. I have removed my egr, aiv, cat, and charcoal canister with no codes thrown.
ditto
ROB240
Car: 240 & Heep
before I switched to the aem I had absoluetly nothing in the engine bay, every single emissions piece is gone and it never once threw a code. fortunately our ecu's are pretty dumb this was on a '93 btw.
