EGR problems PLEASE help..
todd5854
Car: 1994 240SX Convertible Limited Edition, White
I'm about to give up on this but I really want to fix it....
I have a check engine light for code 32. I had a few vacuum problems (mismatched hoses) they are fixed now.
After fixing that, the check engine light would come on sometimes. ... I watched my EGR system, and whenever the light comes on there is no vacuum to the EGR at all.
Now the light is on constantly, and there is never vacuum there.
Where to start looking....? Should I test the vacuum solenoid behind the engin near valve cover???
Please.. and thanks
solallein
Car: 1995 240sx
If you end up needing an egr solenoid or temp sensor I'll sell you one cheap.
todd5854
Thanks man. I just found the testing procedure in the FSM.I'll PM you if I need something.
