G450rep »
https://forums.nicoclub.com/g450rep-u134157.html
Thu May 21, 2009 4:11 am
Go to one of the auto parts places that has the computer to read codes (autozone should have). Tell them you would like to check the codes, which they will do for no charge. When the code displays, ask them to delete it. If they claim they are not allow to delete emissions code, explain to them that you just cleaned out the pipe and then the code showed up and if it is a real fault, it will come back. They usually understand this logic. If they don't, go to the next place and try again. It should clear itself otherwise in something like 50 starts. if not, there is something there, the actual code should provide some in site.
