Please excuse this and don't reply if you have done so on the other post I made... I am posting in two different areas in hopes to get an answer soon.__________________________________________
Ok guys.... I have owned my 240 for about 4 years now and love it!!! I bought it with a full length header and a greddy grapefruit shooter. haha Anyway, I have always have a bad exhaust smell that has never allowed me to pass emissions and makes me smell bad. ( not to mention the headaches )Obviously my cat is gone since I have a full length header, but about a year ago I replace the first O2 and the smell went away for about 2 months and then came back. I learned how to get codes from the ecu and discovered that my ecu has a reoccuring love affair with trouble code 32. EGR Function. Now, the workmanship on the header installation wasn't that great, although it sounds like a true bread race car, it is very obvious the the EGR tube that feeds the EGR valve is totally gimp at best. I decided to break down tonight and buy some more tools to troubleshoot this finally. ( 3 years later ) Prior to looking at this, I replaced spark plugs, distributor rotor, tested resistance on plug wires, O2 sensor again, and check compression on the cylinders. first three cylinders were all even at 180 psi and the fourth was a bit lower, but within limits. For the hell of it I poured a bit of oil in that cylinder to test again.. anyway, after that I put everything back together and cranked the engine. Well, remember when I said that the egr tube connection to my header was totally gimp??? Let's just say that the extra oil that I poured in the cylinder caused a LOT of smoke to exit the exhaust. This was expected, but the problem is that as soon as my friend started the car, blinding amounts of smoke rolled from the connection of the egr tube to header. This area was obviously much worse than I had ever known. Now so you guys don't worry about my engine, the smoke stopped within a couple of minutes. Now to my actual question.
Could this be the sole reason the I have been busting O2 sensors, failing emissions, running EXTREMELY rich, error code 32s, getting poor fuel economy, very sporatic top end and WOT response, loss of power from time to time, blah blah blah???????
I have verified that there is no vacuum from bpt to egr valve @ 2000 - 3500 RMPs. I imagine that is due to little or no pressure being exerted from the header through the EGR tube. I was going to run many more tests on the EGR system with my FSM and vacuum tester, but it started raining so there is always tomorrow!
Does anyone else know of any main problem that is caused by putting on headers that are related to my issues, and lastly, is it rare that I have a full length header, because everyone else seems to not and I can't find them anywhere fore sale??
Thank you everyone for taking the time to read and reply!!!
