hbrown »
https://forums.nicoclub.com/hbrown-u19101.html
Mon Feb 07, 2005 8:24 am
I recently did several mods at once and now have picked up a hesitation in my 89' SOHC. I installed an OBX cone filter adapter with a cone type air filter on the stock MAF and intake tube, also installed a hot shot header- removing the AIV and EGR in the process. I did not mean to lose the EGR, but the darned pipe was stuck so bad I could not undo it and ended up having to cut it off the old manifold with a sawzall. ( I tried the better part of the weekend to get it to come free before sawing it but it just wasn't happening- penetrating oil- heated it- beat on it- pipe wrench- vise grips- you name it.) I plugged the vacuum lines to the AIV stuff- and just plugged the EGR pipe itself. What do I do with the inlet air temp sensorsince I aced the filterbox? I just have it loose right now- could that cause the hesitation? I did a new O2 sensor, plugs, wires, and got out the light and set the timing correctly. I removed the cat years ago. It has a rather bad flat spot and a hesitation now at about 1/3 throttle. If you get on it, it will run, but only kinda half-assed, like it's just going through the motions. Doesn't pull hard like it did- (well, as hard as a na KA is gonna). I suppose I'm gonna have to resort to the FSM- and troubleshooting. I suspect it is EGR or O2 sensor related- has anyone else had these troubles after installing a header? I have a good EGR tube I got off another engine in the junkyard- but I can't even get a wrench on the connection at the EGR valve itself with iton the car. What does it take to get it?
