EGR nessecary for RB20??
gbaz77
Car: 240sx
i was told the EGR from the stock s13 is not needed for the rb20 at all. ive also tried looking at engine pics for people with RBs and it seems that for the most part nobody is using them. can anyone verify this??
also, if im not using the EGR, what do i do with those two little brass lines that come around the back of the ceramic intake arm. do i just block those off with some hose??
Joe
do you mean the evap canister?
krayton
does the rb20 even have egr?
are you looking at your water lines?
gbaz77
Car: 240sx
the EGR from the S13...or at least thats what i was told it was. its the little black cylinder right behind the drivers side headlight. if thats not EGR what is it? and do i need it for the RB20.
and
what do those two brass lines coming across the back of the intake arm (that goes across the valve covers) go to?? i thought they might hook up to the little black canister (egr??) but im probably wrong.
thanks,
gamay
Joe
thats the evap canister
an EGR would take exhaust gasses from the manifold and route them back to the intake manifold. RB's do not have EGR's
you can run without an evap canister BUT you will fail emissions
gawdzilla
Car: none
Kamin wrote:you can run without an evap canister BUT you will fail emissions
think that depends on the state... I don't believe you'll fail w/o one in MD... obd1 they don't pop the hood or anything. all they do is tailpipe sniff and check you have a gas cap.
gbaz77
Car: 240sx
so what do i do with those two little brass pipes runing behind my intake arm? what do those hook up to and what will removing them do? do i plug the holes they are coming out of??
300Plus
Car: 1995 S14 w/ Rb25det Series II
intake arm ?? oh ok wait... I think you are talking about the intake tube that crosses over the valve covers. and if you are talking about that then you are refereeing to the brass/copper tubes that are just vacuum line hook ups. you can run hoses in there place or use them your choice
but it would be a good idea to show us a pic to make sure.
gawdzilla
Car: none
start the car, if you feel it sucking air, somehow its connected to your plenum so cap it off. if not, leave it alone.
