EGR leak cause no idle
Frankenstien93
Car: Nissan 240sx SE
i capped off my egr valve but i think it may be leaking could this cause my car not being able to idle at all?
93 KA24DE
Craving4Boost
Car: 91 240sx fastback
yes your car will not hold idle if there is a leak in the EGR. did you use a gasket or RTV? without 1 of the two, it will still leak not matter how much you bolt it down. if you havent already, go ahead and add a gasket or RTV and you should be good to go.
znelson
Car: 1992 240SX
Used 2 nickels in the fittings and cold welded the fittings, worked very well. Cost me 10cents + some jbweld.
Frankenstien93
ok ive been having no idle since i turbo'ed i think the egr is leaking one other Q is about the IACV i hooked it up to my pcv line and as long as its hooked up it will be ok or does the size of the line have to do anything?
Craving4Boost
the IACV hose should be hooked up to the cold pipe. you wont be able to idle without it...
Frankenstien93
ok right now I had to remove my turbo and go back to N/A. I have the IACV tee'd off the pcv line that goes in between the maf and the TB. ill have some pics in a little while just waiting for them to email. But the big Q was i bought the tee at napa and its about 3/16 in diameter would this be too small or does it matter?
j-z
Car: 95 240sx
do you still have these issues with the turbo off? im having some of the same problems you are as well. i just built my motor and boosted it. what exact symptoms do you have. does your motor shake from side to side? does the motor die instantly if you take your foot off the gas from trying to maintain a decent idle? what happens when you try and give it gas abruptly? maybe we can help each other. i have a thread right around this one, so check it out. im thinking i have a vacuum leak somewhere, but i had no carb spray to check that. did you remove your intake at all? what all did you do and whats your fuel setup consist of and what maf?
Frankenstien93
well since im N/A i put everything back to stock. stock injectors, no fuel managment system, stock MAF and i still have the problems. yes it does die right after i let my foot off the gas. i think my EGR is leaking due to me not using RTV on the seal. but i cant really tell what it could be because it dies before i can get under the hood to look at anything.
j-z
Car: 95 240sx
does it die when you hit the gas as well? you know you can spray carb cleaner (flammable) into the problem area, and if it idles normal for the time being youve found your problem. but yeah kinda hard when you gotta keep it running. i wouldve done this today to my car, but im fresh out of that shlt. tomorrow.
Frankenstien93
yea i think thats what im going to do its going to be a two man job. damn it sux when **** is wrong and you cant figure out what it is ive battled with this for like 4 months now it sux
and oh yea i can hold it at a steady idle if i hold the gas a little and yes my motor rocks alot too
