EGR/Knockers
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
is the EGR robbing my motor of power if im recieving a code 34? i dont really care much bout emmisions as of now, but does having a bad egr kill gas mileage/hp?
i know the knock sensor does right?
EDIT*
also, which code, 32 or 34, dosent turn on the check engine light?
180fan
Car: 89 fastback
A bad EGR can cause a motor to run very rough depending on what it's doing. A code 34 it'self won't knock mileage or power on its own. You'll need that EGR for emissions testing if you're in CA.
S3t0_S13
well my uncle owns a smog shop, so to the EGR
well the motor runs fine, smooth, gas mileage is a bit dissapointing, hp does feel the same though, ( still slow) so ya
should i purchase from that ebay seller everyone was talking about?
