EGR issues on T33... ?
V6er
Car: 2014 Nissan Rogue T32 SL
2023 Nissan Rogue T33 SL
Yello!
seems that there is another new "trend" - issues with egr valve.
is there more technical information - what is wrong, what is going on, can it be tested by diy and fixed?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The EGR system on the T33 is a complicated animal, it has its own cooler and doesn't function on/off above a certain RPM like traditional EGR's. It actually meters the flow of exhaust gas and needs calibration in order to do its job. We've admittedly replaced a lot of valves and coolers. The trouble is, the complexity means it isn't easy to isolate the source of a failure and you need a very serious scanner to do any serious diag on them. For a typical DIYer, the best advice I can offer if you get an EGR code, replace the valve, cooler, gasket, and screen out of hand and let someone with a high end shop scanner (or the dealer) calibrate your work.
V6er
understood!
as always - thanks!
and happy new year! health and happiness! :)
VStar650CL
Technical Expert
Happy New Year to you and yours as well!
:dblthumb:
Return to “Rogue Forum”
