EGR? Im an idiot
chmercer
all i know about this is that it deals somehow with emissions control. dont know what E G R stands for, or what it does, or how it works, etc. could somone please enlighten me? :)
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Exhaust Gas Recirculation.....
Basically a tube that connects your exhaust manifold to your intake manifold. It channels exhaust gasses into the intake manifold which helps keep combustion chambers cooler by diluting the air coming in. The cooler combustion chamber temperatures help reduce NOX emissions.
chmercer
so this would probably be a serious performance limiter, correct? is this hard to remove and reinstall for inspection time? thanks.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
it just the tube that goes into you air intake box from a little black box next to the strut tower, its really easy to remove and put back on.
Just another 240
J-Spec Tuner wrote:it just the tube that goes into you air intake box from a little black box next to the strut tower, its really easy to remove and put back on.
errr..wrong~
Onizuka
well thats the way it is on my car... It is a hard pipe from the exaust manifold to a metal collector that goes up to that black box with the lines on in and then through the rubber hose to the air intake box, just like i said.
Cyberkreig
Car: 1993 Nissan 240SX SR
EZcheese15 - I dont understand how 1000degree exhaust gas will keep things cooler? can you explain?
chmercer
from the looks of my engine bay in comparison to your picture, somone has already done this mod for me i guess? lol, is this correct?
(direct your eyes away from the beautiful exhaust manifold :))
sixxdeuce
Car: 93 rx7, G35coupe 6mt
Is your car an S14? I think only the S13's had that extra little black box
Cyberkreig
it must be S14, you can tell by the Different MAF, and i think there is an IAT in there too
Onizuka
yeah i can tell by the strut towers he has a s14, i guess my example doesnt work then cause i have a s13...
far1002
Car: cars art
that little box you all are talking about is your AIV not your egr your egr goes behind your motor to the back off your intake manifold. YOUR aiv injectes air into you exshast. Thier should be two pipes coming of your exshast manifold and its downpipe. one for egr and one for aiv.
chmercer
yea my car is an s14.
jspec - i have a strutbar? lol, where
chmercer
oh also. this egr thing is supposed to cool off the intake air correct? will anything be damaged if i remove this?
Onizuka
chmercer wrote:jspec - i have a strutbar? lol, where
i said strut tower, not bar ;)
far1002- you are right, i went out and looked at my motor that is sitting on the floor of my garage and there are two difforent lines, my bad, i dont know what anything is called, all i know is that it is a emissions device. (i dont have a FSM or anything)
chmercer
d'oh, i cant read hehe
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Cyberkreig wrote:EZcheese15 - I dont understand how 1000degree exhaust gas will keep things cooler? can you explain?
The exhaust gasses are cooler than the combustion temperatures. The exhaust gasses also have a low oxygen content, which cools the combustion chamber so that the nitrogen combines with the oxygen that *is* there, and creates NOx.
chmercer
is it harmful to disconnect this pipe? it seems that this would increase horsepower with more pure air to combust, but would i burn the exhaust valves or somthing with the higher temperatures?
240marcuSX
Car: E34 525i
E46 M3
OH thats what that thing is!?!?!?! i never could tell.
far1002
Car: cars art
removing your AIV will cause no problems because thats only thier to help your car pass emission's.the Egr can be a different story I don't think that removing it will increase power but if it did it wouldn't be much. But removing it can cause detination in certin cases the egr reduces combustion chameber tempretures and depending on how your car is runing(for exmaple if it is running lean because you have low fuel pressure or some thing and its hot outside thiers a greater chance for detination and i don't think its worth it for a greater chance for detinating. I 'm in the process fo turboing my 240 Its A ka24e and i've just finished the turbo manifold and i'm going to incorperate the egr into the downpipe.
