I have a completely stock 1993 S13. I continue to have problems with my EGR system. I live in Dallas so the system is required for emissions. I have completely cleaned the EGR valve, tube, manifold was removed and EGR passages completely cleaned like new, everything put back like it was before. Car runs fine. The problem is when the engine is rev'ed to 2,000 rpm the EGR valve is not opening to allow the exhaust gas to enter the intake and thus lower NOx. I have checked the EGR and canister solenoid and it functions as the factory service manual (fsm) states. I have a vacuum at the solenoid inlet C when the engine is rev'ed but it never gets to the EGR valve to open it. The solenoid is supposed to turn on when the engine speed rises to 2,000 rpm aand allow the vacuum to travel through solenoid inlet A and on to the BPT and EGR valve. For some reason this never happens. I followed the diagnostic procedure in the fsm on page EF & EC-111, but end up at the check ECM pin terminals at the very end of the procedure and the connection and pins are good. I noticed that the voltage at the ECM terminal 105 stays near 0 when the engine is rev'ed to 2,000+ rpm when it should increase to battery voltage. Seems like the procedure would direct you to the ECM after you do not get battery voltage at terminal 105 but it then directs you to an EGR solenoid harness voltage check.
I know this is a common problem, but I can not find any answers. If anyone knows, please help.
