EGR flow malfunction on a 97 q45 ... so confused
trad1987
Car: 95 240sx
Hey guys, last night i noticed some white smoke coming from my car once it warmed up and freaked out. Checked the oil, no blown gasket. So i brought it to a mechanic and found out it is throwing a P0400 code - EGR flow malfunction.
What im confused about is that while reading up on it, i read that it is
1. clogged egr just needs cleaning2. the tube the connects the EGR to the plentum needs cleaning3. new gaskets
This is saying that i dont need a new egr, just some cleaning.
Does this mean that i dont need a new EGR valve?
Also, is there anything else that must be cleaned?
In as straightforward was as possible, what must be done to fix the egr flow problem?
Many thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Clean the valve and chek the tube to the exhaust, and clean it also if required.
If the passage into the plenum is clogged, the only way to clean it is to remove the plenum, which means you get to do the under plenum hose job. More reading will be enlightening.
