Wc240 »
https://forums.nicoclub.com/wc240-u133792.html
Sun Dec 13, 2009 9:46 am
back pressure and atmospheric pressre are two different things. i made a customer take off his three inch exhoust becouse he didnt have enough pressure to open the valve. generally, if you can plug up the exhoust, then it works, its NOT the bpt valve. there is a step by step test in the fsm to check the whole system. all you need is a vacuum pump/gauge. harbor fright has em for like 20 bucks.
make sure your base timing is in spec.hows your other gases? if it wont drive em up too much, try goin to a higher octaneremove your egr and clean the passages, make sure ALL the vacuum lines are good. you could have a small hole, and plugging up the exhoust makes enough pressure to over power the leak. nox is pretty easy to diag.ive had a few sensors go bad, but not often. i doubt its bad. unless that when you clear the code, it comes back right away.
