smkn92Z32 »
https://forums.nicoclub.com/smkn92z32-u102159.html
Wed Dec 23, 2009 6:37 pm
ok, so i looked over that very helpful info on that link and refigured some of my vacuum lines. i also bought a 68k resistsor and that took care of my CEL.
before i installed the resistor i read my ecu codes. it read 34 and 35. i unplugged my batt for a while then installed the resistor and now no more CEL. but the original problem persists! still boggin out and still idling really low and even shutting off sometimes.
ive noticed my dash lights up sometimes. its the headlight/highbeam light, the door light, brake light and sometimes the abs also. i am aware that if the car dies the lights will light up. i notice this is the case when the car wants to die but cant due to it being in gear and moving. but theres times the lights come on while driving, though it might just be due to bumps in the road and a short somewhere in my lighting. i checked the batt with a volt-meter and its at 11.78 with car off and at 13.47 or so with car on. i figure this is fine. alt seems to be workin fine and it does fire right up every time. i did tighten my alt belt and no more chirping at all.
whats the best/easiest way to do a boost leak-down test on the NA? sorry im sounding like a noob here... i am new to the Z32. thanks again to all.
