95’ s14 wrote:one con no one has mentioned is that it re-routes exhaust gasses which is burnt fuel and air which equal hydrocarbons which means Double the hydrocarbons running through your combustion chamber and that boys and girls is bad for your engine thats the real reason i want it gone, Engine life. I just had a salvage motor rebuilt and i dont want all that s*** ran back through it
um, no. burnt fuel+ air doesnt egaul hydrocarbons. HC's are raw fuel, unburnt gas. when it enters into the intake it is known as an inert(see, non flammable/combustable) gas. it takes up the space(not all of it, like 20-30 percent if im not mistaken) in the combustion chamber. this is whats called a displacement misfire. the exhoust displaces a lil bit of the fresh air/fuel mixture. buy doin this, one, the reused gases are cooler. and they cant burn again. not as much temps/pressure in the combustion chamber. thats what it does.in any case, if it were HC's(wich its not) that would be the same as running a tad rich, not that bad. also, your computer would sense this, adjust, and correct this to bring it bach within the correct fuel ratio for that speed cell at cruse, but this is, once again, not the case.remember, these emissions systems were designed with the worlds air in mind, and engine life, gas mileage, and the consumer. notice that your KA has been seen at 300,000 to 365,000. probably higher. the old motors, with there open crankcases and down tubes and no evap, got what, 9MPG on a good day and went a long life of 75,000 miles? your right, all that emissions is probably killing your engine. i hear carbs will make em last forever
