EGR control solenoid test results. Have comparables?
YleKyote
Car: 1998 Nissan Pathfinder SE 3.3L V6 A/T
1998 Pathfinder 3.3L, automatic, 164,000 miles, stock. Runs real good.
So I'm having a recurring P1400 EGRC Solenoid Valve error come back after erasing codes. It reappears almost immediately after being erased. I don't have any operability issues. No other codes but one that came up after I started running the motor with the solenoid plug disconnected (for testing)...P0443 Evap Emission Purge Control Valve Circuit. But it stopped appearing after I reconnected the solenoid plug.
I looked where the ECM is to access the EGRC Solenoid ground wire and crap is that a pain to get out! So I did these troubleshooting steps to test the Ground wire resistance and the Voltage at the plug wire instead. This is after I tested the valve clicks/opens with 12v injected from a jumper wire. The solenoid appears good, as far as activating manually.
Ground Wire tests: left socket when looking at plug with lock button on top.
ENGINE COLD --
Off cold: 500 ohms
Key on cold: 1,200 ohms
Cranked idle Cold: 3,600 ohms.
ENGINE HOT --
25 minute idle warm up and short drive, and RPM revs to 3,000.
Off: 500 ohms.
Key On: 1,200 ohms
Cranked at 850-rpm idle: 1,600 ohms before revving, 3,400 ohms after revving 2,000 rpm.
Cranked and held at 2,000 rpm (in Neutral) for 60 seconds: 1,850 ohms.
### VOLTAGE tests ###
Power Wire: right socket.
Using ground wire on solenoid plug (motor cold) --
Off: 0.01v
Key On: 11.9v
Cranked: 14.3v
Using chassis ground frame bolt (motor hot) --
Off: 0.07v
Key on: 12.4v
Cranked: 13.7v
- Battery terminal as ground had same results.
If nobody knows I'm just gonna ignore it because I dont have emissions tests here and it shows no driveability issues either, so likley unimportant.
But I kinda wanted to understand if my EGR is being left open to exhaust or closed, with the signal from the solenoid as-is. Anyone know by chance?
Thanks!
mdmellott
Car: '13 Kia Soul+ 2.0L AT
I would repost here what I just posted in reply to this posting you made in the original post6850709.html#p6850709 but double postings are frowned upon.
YleKyote
Yeah sometimes I think it needs to go in two places for topics. Thanks!
