wade »
https://forums.nicoclub.com/wade-u55977.html
Fri Mar 14, 2008 12:35 pm
First off , can't do it is not a question , it is find a way and do it..
To get to the EGR valve , I laid a 3/8 sheet of plywood across the engine area to the tops of the fenders. This safley created me a place to just lay on top of the engine and gave good working access to the aeagar valve area. My worst problems was getting my arms in some of the areas . They were sore for a couple of days.
I will check the codes again , I did try a tube to the EGR and manualy operated it. The diafram works and then with the car running manualy opened it causing the engine to run ruff , took off the suction and it smoothed out. I feel like the EGR is not the problem.
I am down to either the EGR solenoid or may be MAF .
I went to a Infinity dealer and talked with a tech. He said even with there Machine sometimes they just end up swapping parts till they find the solution ..... He said the EGR valves very seldom go bad. He leans more to the MAF or possibly a ground ?
He said that since I cleaned the tubes that it just leaned out the mix and made the surge more pronounced.
On the way out , I noticed they had a G35 doing a short block on it , A ton of parts laying on the floor.
Funny thing was , My wife had a G20 , and after service at the dealer one time , oil pressure was low , I returned the car to them and it had a cracked block. They warentied a short block and dufing the repair I dropped by. One of the tech. showed me a nut they found in the oil pan . Seems they had dropped it in the engine durring service !
They stood by it .
Ok , Back to my problem. Anyone worked with the MAF ?
