Although I don't seem to have any issues I will also work on this eventually.Q45tech wrote:Every gasoline engine in US eventually gets a dirty egr system depending on the percentage of cruise vs idling and acceleration hours/miles.
35k mi. ago, when installed jdm motor.my motor used to stall out completely when diaphram was compressed.maxnix wrote:When's the last time you cleaned your plenum?
Cleaning the EGR inlet on the plenum is just about impossible without removing the plenum.
will domaxnix wrote:Watch you throttle body cable pulley/cam when someone abruptly releases throttle from 2500rpm. Is it slow to respond? Do you have enough slack in the adjustment?
