Craving4Boost »
https://forums.nicoclub.com/craving4boost-u23486.html
Tue Aug 16, 2005 2:40 pm
well i thought it was the BTM causing me not to idle but i made sure it was wired correctly...now within this week ive installed the BTM and blocked off the EGR..so i decided to check out my EGR
i removed the whole egr right off the intake manifold and blocked it off at its source with a plate structure gave to me. i left the thing next to the EGR whatever the hell that was. that thing had 2 vacuum ports that used to connect to the EGR so i capped it off with rubber vacuum caps. now i took off the EGR plate to see if anything changed. little changes occured.
so now i put back the EGR plate but i did not bolt it on because i just wanted to see what would happen. now for some reason it actually idled this time! but its jumpy. i went back to look at the EGR plate and it was slightly open making it partially covered and open. now i decided to take off the plate to see what would happen, and then i pulled it off (which was kind of hard because it was sucking the egr plate in so hard) and once i took it off, my idled died immiediatley. so my big guess is that it has something to do with the EGR. did i do something wrong?
