EGR block off...voice yur opinions
SR20drftSX
Car: 240 hatch(sold) , 92 Infiniti G20 JDM Sr20
alright...soo im thinkin bout removing the EGR valve on my kaE and was wondering what yu guys thought about this..yes i searched and juss found one for sale is all... they sell block off plates on ebay....but my bro is a machinest so im juss gonan have him make me one..but what do you suuggest to plug up the header hole? and what other opinions yu guys got...just shoot em out
JeromeS13
Car: 2008 Subaru Impreza STI
There's a Nissan part number for a plug that fits in there. Do some searching around. I'm sure its around here somewhere.
SR20drftSX
and what would this "plug" be called?
JeromeS13
Wow. I took 15 seconds and searched for "egr plug". 14052-21R00
SR20drftSX
atta boy
SR20drftSX
atta boy...
bige240
DO IT!! remove all that crap, it will not hurt your engine or throw any codes. You can get a egr block off plate on ebay for 10 bucks....the only reason I would say not do it is if you are subject to inspections and emissions tests, you may not pass if you remove it.
SR20drftSX
yeha..ny they just chekc yur engine lite and stuff..and no sound tests or smog test..so i think itll be good
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Good info
SR20drftSX
yep
hek1620
Car: '89 240sx
this is the way i blocked the header holes. saw or cut both of those pipes about 1 1/2 inches from the nut. weld the pipe shut, and bolt it back on. we did this with a small torch and a metal clothes hanger. i also had the head port welded shut. but this was done with a real welder obviously. ur gonna feel a little kick in the pants when u remove ALL of that crap.
SR20drftSX
good to hear
SR20drftSX
could i just simply screw out the opening for the egr pipe on the header..place some nickels back in there and then close it up? and essentially block the gasses from going back into the intake? or would it run differencelty than removing all the junk?
180fan
Car: 89 fastback
it'd probably run a lil better once all that stuff's removed. but if you live in a state with more stringent emissions policies, you're much better off cleaning the egr stuff and getting it back on rather than having it pulled and having to put it back on later.
SR20drftSX
yeah i figured..but would it create vacumm problems if i just simply plugs the header hole for the egr tube with a nickel or two?
bige240
what I did on my car was cut the pipe with a sawzall about 6 inches from the header and hammered a big bolt into it...It worked for a couple weeks until I got my aftermarket headers in...Probably would've worked longer... Just make sure that the exhaust can't get thru the hole... the best way would be to unscrew the pipe from the header and mig weld a bung over it...
lbrowne
JeromeS13 wrote:Wow. I took 15 seconds and searched for "egr plug". 14052-21R00
Does that plug the header?
SR20drftSX
yeah that should plug the header
8-bit
Car: 1991 240SX KA24DE (T in planning)
OHO! Let me tell you hwo to plug the header!!!
You know the pipe that comes off the header that goes to your EGR? get near the neck of it (where it screws into the header) and cut it through. Then pull the part that screws into the header off of the pipe...
Now this is the expensive part... get yourself a nickel. you might have one in your pocket, but banks have them too. Put the nickel in the hole in the header, then screw in that pipe-fitting (minus the pipe you cut off it) right into it..
Voila! You may smell a little of the nickel's coating when you first get your car up n' running but it will go away in 2-3 minutes.
I did this with the PAIRC and EGR system tubes on my KA24DE. 10 cent upgrades!
8-bit
SR20drftSX wrote:could i just simply screw out the opening for the egr pipe on the header..place some nickels back in there and then close it up? and essentially block the gasses from going back into the intake? or would it run differencelty than removing all the junk?
AHA! boy do i sound like an *** now...
cut the pipes though.. you don't want useless mess inyour engine bay... cut it all.. save the retaining nut thing.. nickel.. put in.... pimpin.
SR20drftSX
hahaa it was the thought that counts
