EGI
dqueener
Car: 91 nissan 240sx
egi not sending power to fuel pump. tried 5 egi's and have power to plug for egi. help...what am i missing
theother1wstolen
Car: 92 240sx Coupe SE
checked the relay for proper operation? checked for harness continuity from the front of the car to the pump?
vancouverbc
Car: 1991 240sx
the egi relay does not send power to fuel pump. the egi pump relay does.the egi relay sends power to fuel injectors.
re.: egi pump relay
pull the relay out and test to see if two terminals are 12v+. one of the terminals will be ground . the computer sends ground signal when it wants fuel pump on. in other words, computer controls when fuel pump is on by sending ground signal.
zerothread?id=140879
Modified by vancouverbc at 2:07 PM 2/16/2007
