lglusco »
https://forums.nicoclub.com/lglusco-u41467.html
Wed Jul 05, 2006 7:48 am
The Nissan dealer couldn't help, maybe someone here can. I hope.
My situation is, 9 times out of 10 I can only start my car by removing the EGI relay and inserting a piece of wire (see photo).
Here's the history, brief as I can do it: 1. In April, drove car to airport and parked. Came out 10 minutes later and car would not start. Had it towed to nearest gargage. They thought it was ECM problem and sent me to Nissan. This was while I stilled lived in Texas. Nissan dealer said, "hey, you're in luck, it's not ECM, it's EGI Relay and fusible link. I had the fusible link (part # 24370-89905) and relay assembly (25230-C9965) replaced. According to the work order, the link (24370-89905) was blown and the EGI relay (25230-C9965) was shorting out.2. About a month later, after moving to NJ, my battery went dead. Got a jump start and went and had battery replaced. Less than two weeks later, battery dead. Key got stuck in ignition. After charging battery, key came free but car would not start unless shifter was in Nuetral rather than Park. Bought a battery charger and started keeping track. Sure enough battery would drain and go dead in week to 10 days. Occasionally car would start in Park but most of time I had to use Neutral. Started doing that every time just to avoid the hassle.3. Took car to local shop. Their guy said the EGI Relay was staying on and draining the battery. He said I'd probably need to have the ECM fixed or replaced and said a Nissan place would have the proper diagnostic equipment and be able to help me out. Nice guy, said he never charged people if he couldn't fix their problem. He showed me how to use the wire to start the car. Said to remove it when not using the car to keep battery from draining. 4. I thought, why not just take the EGI Relay on and off rather than the piece of wire. I tried it and that worked fine. Figured I'd do that until I could get the car to a Nissan dealer.5. Took car to local Nissan dealer, giving them the info I've laid out here. I was going out of town, so they had the car for more than a week. They called me late in the week and said they couldn't find a problem. Said there was no draw. I said OK, I'll pick it up Monday after I get back. I was sure the car wouldn't start Monday morning, and I was right. Battery so dead the clock had the wrong time and the radio pre-sets were gone. I went back inside and asked for a jump. Got car started, took it home, recharged the battery.6. Following this, car would only start using the piece of wire. I thought maybe the Relay and Link got fried because Relay was on car the whole time it was at Nissan shop. I ordered new ones, but them on, now car would start with Relay on first time in the morning, but later in day it wouldn't and I had to go back to wire method. Also, when I'd put the Relay on and try to start car, car wouldn't start but I'd get a buzzing/humming noise. When I insert the wire, the noise goes away and the car starts right up.
Sorry, that's not very brief. I'd greatly appreciate anyone who can offer some insight. Anyone know of a Nissan tech who might be able to help me? I live in NJ near NYC and Newark, NJ. I'd be willing to drive somewhere on the East coast to get some competent help. I'd really like to get this fixed right, because otherwise the car runs fantastic with 163,000 miles on it. Also, if anyone can explain in simple terms what the EGI Relay and link do when I turn the key, I'd really like to understand what's going on here. What is being bypassed by the wire method? Any idea what that humming noise is?
I guess I'll look for another Nissan dealer. Since I'm new to this area, it's hard to know where to find good help. Again, thanks for any insight or suggestions.
Modified by lglusco at 1:14 AM 7/11/2006
Modified by lglusco at 11:04 AM 9/30/2006
Modified by lglusco at 11:05 AM 9/30/2006
Modified by lglusco at 11:29 AM 9/30/2006
Modified by lglusco at 11:47 AM 9/30/2006
Modified by lglusco at 11:50 AM 9/30/2006
Modified by lglusco at 11:51 AM 9/30/2006
