Onizuka »
https://forums.nicoclub.com/onizuka-u2660.html
Wed Jun 29, 2005 7:59 pm
I see the light. And you only had to explain it to me three times I was a little too absorbed with the spring rate constant. J-spec bows to your knowlege (heck I should be the one asking you questions)
I think with motorcycles preload effects ride quality more because it is able to completely unload either wheel with relative ease, making that preloaded travel a larger part of of the overal suspension dynamics. Preload is also how they adjust ride height, seems like a double edged sword to me.
However, now concidering, if traveling on a sub-par highway at 60+mph with a sunden drop in pavement, preload could dictate the speed that the car recovers from down-up motion after the bump. I was reading whiteline's FAQ and they say they put only a very small amount of preload on their coils, just to keep them from moving around on the perches. However, I replaced stock struts for my freind 2 weeks ago on his saturn and the springs were preloaded a good 1.5 inches at least. How would you begin to even tune for preload? Only posible on a shock dyno or is more of a feel thing. Ive done single adjustable damper and camber tuning at the track, but we never touched on preload.
I guess it would help to have seperate compression and rebound damping adjustment if your going to be messing with preload.
