Effects of a wastegate leak
myRed240
Car: '95 Nissan 240SX with a KA-T!
'07 Audi A3 2.0T DSG
'11 G37S Sedan
I have a leak at the flange where my wastegate connects to the dump tube. The dump tube is recirculated to the down pipe. The original gasket blew out, and I ordered a metal replacement, but ATP sent me a composite gasket. This compound gasket is too thick and is causing a leak......
Would there be any problems to driving around town (besides noise and exhaust fumes)?
I don't plan on any speeds above 40 and I probably won't get into boost
Thanks guys!
Ligouri Rd
Car: '96 Nissan 240SX
As long as it is just the connection between the dump tube and the wastegate then you should be fine. There will just be loud hissing through the leak whenever you get into boost.
C-Kwik
Just make sure the leak isn't right next to something that might be sensitive to heat.
Riubens
Car: ka-t 240 and 99 Q45 t
myRed240
'11 G37S Sedan
Nothing sensitive to heat is next to it. Besides, I'm not really driving it until I get the right gasket in there. I just needed to run a few errands today before I go out of town. I hope the leaking gasket is the root of an odd sound coming from the engine bay....
On another note, I just received an email from ATP offering to replace the composite gasket with a metal one for FREE! Finally, someone making a mistake and offering to fix it....
Chezedik
Car: 1991 Nissan 240sx
It will just cause you to underboost. So long as you don't set something on fire.
1WheelWonder
What about a leak between the wastegate flange from the manifold to the wastegate itself, what kind of issue would that cause?
nissanfanatic
Car: 1992 Nissan 240sx SE
Anything pre turbo that is relatively small is just going to cause a higher boost threshold and possibly more lag. If it is a large enough leak, it may cause a lower peak boost pressure. When my wastegate runner broke almost completely off, I could only hit about 16psi as opposed to my normal 22psi..
Anything post turbo can potentially cause creep if your setup is setup to use exhaust restriction as a boost control aid.. You shouldn't design your setup like that for a street car.. You should size and position your wastegate to be able to sustain the amount of exhaust gas flow to keep boost pressure under control..
Chezedik
Know what, I think I would still take 16psi.
