Carl H wrote:also to all those people who claim that their cars 'dont overheat' using efans, what gauges are you using to monitor coolant temps...i have a pfc as well as defi gauges mounted in the head.
The setup:My brother "Wulfgang" built my car, but I think my info is correct. RB20. Dual Perma Cool(?) 12 inch fans. He built a controller for them. The first one kicks on at 80*C, the second one at 90*C. A/C works. To make the A/C cold while idleing, I wired/w diode the A/C relay to the second fan relay. The radiator is the stock KA radiator.
In the summer, before I wired the fan to the A/C, the first fan kicks on when you're sitting there, or driving slow. Second one would occasionally kick on, but not for long. Summer temps here are usually in the 90's.
Now, with outside temps lower, the fans rarely kick on. That sometimes happens when I am stopped in traffic. But they don't stay on. They're off more than they're on.
If I'm not mistaken, your gauge is usually driven off of the sensor in the radiator. Your ECU uses the one up on the engine usually not too far from the thermostat. Remember that when your gauge says cold, but the engine is hot.
With my consult, which is reading the engine temp sensor( not the radiator), it usually shows around 82-84 degrees.
So the engine is at 80 degrees or so,... and according to when the fans are kicking on, the radiator is less than 80 degrees probably 98% of the time.
This is a daily driver. I drive it to New Orleans every day which is an hour and 15 minute commute,.... and very often I'm stuck in stop and go traffic. It has never overheated. As a matter of fact, before my brother made the controller and just had the fans wired up always on, the car wouldn't warm up if it was left idling.
Now,.. I didn't write this to say anything about your install. That is cool that you did it that way. There are lots of "best practices", that in some minds become "rules". Like the KA radiator. It may not work for everyone, but not everone has the same setup.
Gene
