pgt892 wrote:Can anyone give me a heads up?
http://sr20det.nismo.org/srtech.htm This gives you the pin-outs from the ECU, wire colors, and what they are. You won't find a S13 SR20DET schematic anywhere, if you do let me know.
It sounds like you need to trace the speed sensor wires for the speedometer. The way I understand it the signal goes from speed sensor to speedometer, to ECU. So if your speedo isn't working the signal isn't getting there. I'd suspect the connector below the fuse box in the engine bay. Which lower engine harness did you use? If you used teh SR harness you might need to change teh position iof some of teh wires in the plugs there. Not sure I usually use the KA lower harness.
Why you tach isn't working.... well you'll need to have the correct wire yellw/red pin#2 SR ECU connected to the correct wire on that big S14 dash plug (probably also yellow/red, but I don't have teh schematics now).
If you have any specific questions I might be able to help you out, hopefully this has given you something to work with.
-Martin.
