ecu wiring
240MANs13
Car: 1990 nissan 240sx
I HAVE A 1990 240SX THAT CAME WITH A SOHC AN I RECENTLY DID A MOTOR SWAP TO DOHC AN IM USING THE ECU FROM THE SOHC I GOT THE PLUG FOR THE DASH I JUST AINT SURE HOW TO WIRE IN THE DOHC WIRING HARNESS THAT I ALSO PURCHASED INTO THE SOHC PLUG FOR THE DASH
project-x
Car: 1990 240sx
just match the colors up its very simple you should have three or four wires left that you will not use just tape them up so you have no arching and the sohc ecu will not work on the dohc you must use a 91-94 dohc ecu hope this helps
240MANs13
dude you dont know how much i appreciate that i been jackin with that stuff forever man thank you
project-x
Car: 1990 240sx
its all good i was really lucky when i was searching for the info it took me a month to find all that i have
you do know that you have to get a 91-94 maf and distributor for it to work
240MANs13
hey man i got one more question i dont have a/c or power steering so im not sure how to get a belt cause i dont have a tansioner to make the belts tite
DALAZ_68
Car: 90' 240sx CA18det
i wonder if u even know how to use the search function ...
that wire info is everywhere
if u dont have a tensioners pulley then u need to get one...
project-x
Car: 1990 240sx
240MANs13 wrote:hey man i got one more question i dont have a/c or power steering so im not sure how to get a belt cause i dont have a tansioner to make the belts tite
i supose your talking about the water pump pully/belt you will need to get a dohc p/s pump and block off the holes some how then you will be able to get it tight
