elwesso wrote:On my setup I have the TCU completely removed, and everything works fine. The ECU's 4th gear map is actually "determined" by the ECU. The TCU doesn't "tell" the ECU that it's in 4th gear, the ECU determines it by speed, RPM, and load.
I don't think that the TCU actually uses engine RPM so much, 90% of the transmissions function is controlled by the TPS.
Okay, thanks for your imput. So I don't need the ecu connected to the A/Tcu ? All I have to do is make it think it is always in (N/P) and disconnect the ecu from the A/Tcu?
The car runs strong in 1st and 2nd but 3rd it runs to richer and feels much slower so I just want one map to worry about lol
