allensteiner wrote:it's not a semi - the engine doesn't vibrate enough and poly bushings dampen better than rubber
Ok, previous experience with poly mounts in GM w-bodies led me to believe that thy would increase vibration i these cars. For example in a Lumina if you replace the dogbone bushings with poly units, you feel more vibration... ther's not necessarily more vibration but it is felt throughout the car more.
allensteiner wrote:...ask me what vb means
w0t dose vb meen?
allensteiner wrote:you forgot about the resonator - it'll make your intake a little louder.
Will removing it make things unbearable? I'm gonna replace parts of the exhaust piece by piece and will probably start in that area...
