ECU turning off when cranked
JimmyJames1
We're trying to start my newly S13 SR20DET'd 1997 S14, and we're having trouble with the ECU. When we have the key in the 3rd position, interior electronics work (radio, lights) as they should. When we turn the key to the 4th position where the motor cranks, the ECU cuts off and the engine isn't getting spark. We had the wiring harnesses professionaly spliced. Has anyone had this problem? I searched and found nothing.
Cyberkreig
Car: 1993 Nissan 240SX SR
When i crank my ecu light goes dead. Also all my accessories tapped into the ECU power turn off. This is normal.
JimmyJames1
Wait, are you talking about the little red light on the ECU. That's supposed to turn off when the motors cranked?
Cyberkreig
Mine does, and my car starts. Sorry to give the bad news but the problem is probably elsewhere.
Nismo_Freak
Car: 89 Nissan 240SX
Fuel injectors are controlled by the ECU so your ECU is working.
You might have an issue with your ignitor.
JimmyJames1
So if the motor is cranking then the ECU is staying on and the ECU is not the problem?
JimmyJames1
To clarify, the injectors aren't pulsing but the fuel rail is charging up.
Cyberkreig
JimmyJames1 wrote:To clarify, the injectors aren't pulsing but the fuel rail is charging up.
No fuel injector pulse.No Spark?
Working Computer.
My Bet is CAS.
