Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Aug 05, 2005 2:27 pm
You will not be in desperate need of ECU tuning until you start to dramatically change the characteristics of the motor (Cams, turbo, injectors, compression, etc.). However, simply changing the exhaust can be enough to make the stock program inaccurate. And FYI, the 'low performance KA' as you called it has a lot of guys hitting 400+ horsepower, so it may not be a bad option (and certainly cheaper, or better in the end), to build up your KA. Even if you don't want to boost, 250-300Hp is attainable with the right parts and tuning.
