ECU tune
lilskyline240
Car: 90 240sx w/ rb30det
Alright i need an ecu tune for my KAT project....is there anyone that knows how to do it or should i just go with JWT or enpathy.....i have a z32 maf, deatschwork 650cc injectors.....if i would go with JWT or enpathy what one should i go with??? Ive heard the JWT tune runs too lean....
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Tune it yourself, get a basic daughterboard or a bikirom multiboard, then check out eccs.hybridka.com
I have uploaded a basemapper excel spreadsheet onto that forum, calculates/scales for injector and turbo conversions. This will get you started as good as a jwt tune.
lilskyline240
Im not good with electronics at all....i would proly mess it up....where would i get a daugherboard??
wild_maxx
Car: 90 TT pearl yellow z32
hey devious you wanna tune my ecu when i get my next ka-t up and running? You know way more about tuning than i do
deviousKA
lilskyline240, you might want to look into the bikirom multiboard http://www.bikirom.com . This is generally the same as tuning with a basic daughterboard, but offers ease of use.
With a basic daughterboard you need to burn new chips for each tune.
With bikirom you can update via usb with you laptop, while key is on, car off. Also offers maptracing.
Shawn, I could help you out with your tuning. You wouldnt happen to have a laptop with good battery? In order to run some logs one will be needed, I have to run ghetto power inverter to use mine in the car.
Modified by deviousKA at 6:43 AM 11/10/2005
wild_maxx
yeah i do have a laptop with a good battery you need to do some more tuning?
deviousKA
Power inverter isnt bad, I have it hardwired in and would have to transfer all that is the only deal. My laptop is a beast but it works good.
Chezedik
Car: 1991 Nissan 240sx
Devious, where do you post from?
canadians14det
Car: 1996 240SX DE-T
I would not go with JWT if i could go back and do it all over again. I think most people on here are more happy with the tuning that Enthalpy does. For my tune anyways (50lb CobraMAF) JWT is usually over rich but on a less common tune that they would have to do with 650cc injectors who knows how it would end up.
