ECU Temp sensor
pgt892
Car: 1997 240SX
I didn't really think the ECU temp sensor might be causing problems for me until I read another thread. I already replaced the SR instrument cluster sensor with a S14 KA sensor because it was sending the wrong signal to the temp gauge. Does the KA have a similar ECU temp sensor that I could use or do I need to get another SR ECU temp sensor. If so where can they be found?
rudee023
Car: '03 Infiniti Q45
You can use the KA24DE ECU temp sensor.
pgt892
Car: 1997 240SX
Thanks much. Do I need a S13 or S14 sensor?
Silvia007
Car: 93 Nissan 240SX SE Fastback
If you have a S13 SR going into a S14, then you need to keep ECU temp sensor with your S13 ECU, Only thing you need to change is the gauge temp sender. What problems are you experiencing by the way?
pgt892
Car: 1997 240SX
The problems I am having are common from my searching. The car starts kind of rough, it wants to die for the first min, then the idle evens out to ~800. While driving, after putting the car into neutral from any of the gears the car's rpms will drop down to around ~500 and it has completly stalled out twice.
