ECU Technical Question 91 240sx
mickeyd420
Car: s13 92 se
I cant get a awnser can anybody check this out and make some sense out of it..
zerothread?id=338943
BTW im mickeyd420
r3v_v3ng3
Car: 91 fastback ka-t
the only difference that i see on the chart is on the REG. one is a C and the other an F but i don't know what the reg means.
mickeyd420
Car: s13 92 se
does anybody have any input on that difference?
Vegascorbin
Car: 1990 240sx dirt track race car
As far as I can tell the "F" and "C" refer to Federal and Califonia emissions.
Back in the day Califonia had their own set of emission standards for cars that were more strict than the federal.
California cars had differant settings to meet the different standard.
mickeyd420
Car: s13 92 se
so would that effect my car running proprely?
r3v_v3ng3
hmm. maybe. i know CA emissions is more strict and maybe have more emissions/sensors compare to a federal vehicle
Goldeneagle
Car: 1992 240sx Coupe
The 28 ECU is for a 91-94 base model 240sx with manual transmission.
Modified by Goldeneagle at 11:49 PM 7/1/2008
Goldeneagle
Vegascorbin wrote:As far as I can tell the "F" and "C" refer to Federal and Califonia emissions.
Assuming you are correct on the "F" and "C" what would the "M" and "U" refer to?
Vegascorbin
Sorry for the slow response.all of the "M" listings show Mexico for a Nissan Part number. I would assume they were only foir use in Mexico.
All of the "U" listings I looked at were OBD2. I am guessing that it refers to a "Universal" ECU that is smart enough to know if it is manual or automatic.
Not an expert but educated guess work
twistedsymphony
Car: 1997 Nissan 240SX SE
1995 Infiniti Q45
As others have stated F and C are Federal and California
U = universal emissions... (which started with OBDII in 1996) meaning not federal or California but universal (at least for America)
no idea what M stands for but Mexico is a pretty good guess IMO...
even "universal" ecus are different from Manual and Automatic...
ecus can differ on the following aspect-Chassis style (hatch has different ecu than coupe)-year range (89-90, 91-94, 95, 96, 97-98)-transmission (MT or AT)-emissions (F, C, U)
I would highly recommend replacing your ECU with another of the same number, you can get away with swapping them but you might need to make some changes for it to work properly.
Swapping a federal ecu into a California car you might run the risk of the ECU not understanding the more restrictive emissions systems on the intake and exhaust and as a result it doesn't run properly.
alternatively the sensors ranges might be different and the ECU can't interpret them properly.
the O2 sensor and MAF are sometimes slightly different depending on the ECU too.
Vegascorbin
Good answer.
Thanks
mickeyd420
Car: s13 92 se
so i should only replace the ecu on my car with the number ecu it came with witch would be ecu #30... i found a number 28 ... so i should not get it?
