S13FX wrote:
I plan on having Tomek and me test a lot of the new features out on his car. But I don't see why with a little bit of work the SOHC ecu can't be taken and adjusted for like the SR, DOHC KA, etc etc.
Il definitely do some more research on this and report back ...
where you been? I really should have made a thread in the kat forum sohc on dohc handled! been running with SUCCESS for a good bit now. setup was stanza ecu/maf dohc injectors and dizzy and rest of the stuff, n/a for like 2~3 months, boosted now with z32maf and de injectors, drove with sohc maf for a while boosted without issues.
dizzy needs to be clocked or slotted out to make the dizzy signal usable, feedback control also needs to be changed to the de value rather than the e value. from there its input the de maf vq or wire in a sohc/other maf and adjust for it...
this is by far the cheapest way to go for rom tuning a ka motor. with wideband I'm under the cost of a new neo afc. It works too says the 1000+ miles of boosted abuse. Its one chip vs 2 for a d/board, a socket and 3 chips is less than the d/board itself before chips or zif sockets.... I'm cheap muther funker so I made the sohc stuff laying around work.
if you want to have a look at the .bin file its on hybrid in the rom section, its for t25 sohc maf and de injectors at like 60psi. I need to update that to my z32 bin when I get finished.
