goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Mon Aug 23, 2004 4:40 pm
I'm so frustrated, the car is finished and ready to drive, and I had it running right once or twice, then the battery died. Now, every time I hook up the car battery, the ecu just starts blinking its LED on and off constantly. I can't go into diagnostics mode or anything, it just blinks like it is in the limphome mode or something.
It runs, but with horrible timing and it's very rich too. I have unhooked battery overnight, pushed brake pedal..etc. Nothing clears the code, so is my ecu bad or is it a bad ground?
I was thinking maybe it was something to do with my constant or switched power to the ecu?
Any idea, like the stock security system, a bad ground, or anything that could be causing this would be much appreciated. I wish I had a totally stock ecu to try on the car, but I don't, so for now I have my eprom programmer hooked up and it can reprogram, but it's just stuck with the check engine light flashing on and off and running crappy.
Nick
