Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Oct 19, 2012 5:02 am
More than likely, it's the ground for the shielded wire. Both the MAF and CPS ground to the same engine ground. The CPS goes one step further and has a physical ground coming from the CPS to ground out to the same ground. Granted, this is for 91-94 motors. If you pulled the MAF from that ground circuit and grounded it to a devoted ground, I don't see how that would kill your timing. It's pretty standard practice to do things like that when there are MAF issues or when upgrading to a larger MAF.
I think the issue is in the safc. I've never particularly thought they were any good as anything modifying sensor signals to fool the ECU is bound to cause issues. I would make sure that it's wired into the system properly since pulling it from the circuit causes the car to run fine. SAFCs are designed to intercept the MAF signal, so if you unplug the SAFC, how is the car even getting the signal? The signal wire should be cut and diverted to the SAFC (in series).
