ecu speed output?
Fenvy
Car: 2005 350Z Base 6MT
hi, I was wondering where is the best place I can tap this? I have a black s13 sr
Fenvy
bump
Cyberkreig
Car: 1993 Nissan 240SX SR
Give me some time, i'll try to look it up.
Cyberkreig
Edit: yeah. that pinout is wrong.
Speed sensor has two wires. Y/L and Y/B. Connector number M211.
These wires both run up to the combination meter. Where Y/B terminates and Y/L becomes Y/R. Y/R Runs to the ECU at Pin 7.
So you should be able to tap under the hood in the engine harness number 2 or main engine harness Y/L. or at the ecu using Y/R at pin 7.
I'd check my work before you close it all up.
Modified by Cyberkreig at 2:05 PM 10/2/2006
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
my redtop w/ 63 ECU (but it's a 5MT. XAT says 63=62 when i bought it, but i think the idle and warm-up routines are bogus. once i chip it i'll find out i guess) is the same i'm pretty sure. i hooked up a meter off of it a few weeks ago and red/yel sounds familiar for the speed sensor. just as a note in case anybody is wondering with a redtop/62/63 ECU.
97240via
Car: Basketball, Cars
The 62 & 63 ecu can both be used on the manual transmission. Ony thing is that 63 will wait till you totally stop to lower your rpm. Someting to do with the throttle position sensor i believe. As far as question where to hook up the speed thing (i am guessing something like greddy turbo timer, blitz power meter?) use this diagram here.
Fenvy
that;'s strange, I tapped it to pin 7 (black/green) and nothing happen
my power meter does not read it... I need to check my connection again later
oh yeah I am on an E5 ecu... well power fc that replaces e5
ILikeMy240sx
Car: SR Power
It's terminal 32 of the ECU. It should be Yellow with Green stripe. This wire should also go to your gauge cluster plug. It's the only Y/G wire that goes to the gauge cluster plug so you can splice it there.
Fenvy
32 is "ECU speed input"
I need "ECU speed output"
it is not the same thing is it
ILikeMy240sx
Car: SR Power
You need the speed sensor reading and thats where you get it from.
This is how I have my HKS Turbo Timer hooked up and the turbo timer measures my speed (0-60, 0-100, 1/4m time, etc etc)
BTW, there is no such thing as speed output from the ECU. The speed measurements are given to the ECU from the speedometer which in turn gets the signal from the speed sensor.
There would be a speed output in the speed sensor which is equivalent to speed input in the ECU because the signal travels like this: Speed sensor -> Speedometer -> ECU
