Ok, here we go...
I did a ka-e to ka-de swap.
I have a 94.5 motor (irrelevant)
I sourced every part for the swap.
I wired everything correctly. (As far as I can tell)
The problem:
The "EGI" relay buzzes
So I swapped it with the other green relay (Fuel Pump)
Then both buzzed in unison. (Whatever)
I put the fuel pump relay back (which didnt make a noise in the first place till swapped.), then i tried to start the car....smoke smokety smoke smoke smoke !!!!!!
Now idk what ****ing pin this **** is on but the resistor or cap (idk) exploded? "q456"
Someone help me figure this ****ing **** out, cause I had no ****ing problems with the stock **** on my car when I just had the ka-e....
Pics:
http://s358.photobucket.com/al.../omfg/
If you haven't done a sohc to dohc, don't ****ing bother :/
If you feel the urge to call, 336-926-0641.....help will be very appreciated.
