ECU Shuts off PLZ HELP.....
bustiegtr
Car: Anything and everything with racing and sports.
Ok first off I recently did the Redtop swap into a 1991 nissan truck. I now have a problem the truck cranks but when I crank it the ECU(#63) shuts off. I have no idea why so I thought well let me try and run the wires directly to the battery and see if a constant charge would keep the computer on and nothing the ECU shuts off again. I am stuck now with no clue on what is going on. I talked to some other people about it and they said that I might have the Type X harness and the #63 ECU wont work with that harness. Well they sent me a pin diagram for the Type X and the plugs didnt match up so I guess I have the right harness for the redtop. I have ran power to the orange igniton wire on the ECU to atleast get that power too but nothing still turns off when cranked. Could my ECU be bad? I have no spark, no fuel, and no power to the ECU. Please any help would be great as this thing is driving me nuts!!!!!!!
Nicksemianiw
Car: JDM 89 Silvia K's
Pull it out and put it back in 5 min later (resets the ecu) of that doesent work you might have a bad ecu.
