Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Wed Mar 15, 2006 6:36 am
You might have to check the pinout of your wire harness if your importer can't tell you. Pretty crappy that they're not sending you a new ecu. I'd demand one.
Anway, there are two different harnesses for blacktop engines...one uses the more common pinout for #62 and E5 type ecus while the other was pinned for J4 (like mine). If you get the wrong ecu, you'll have to repin your harness (not a big deal, just letting you know). Since you have a blacktop, I'd at least get an E5 since that is what's meant for your engine's sensors.
