ECU's
mikes94q
Car: 1994 Q45 61k
can anyone tell me the difference between the 4J and the 4E ecu? And can you swap them out? Thanks
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Post the full part numbers and for what car you want to use it on.
Q451990
lino wrote:Post the full part numbers and for what car you want to use it on.
Ditto.
There are two part numbers for each ECU. The JECS number, and the Nissan number. The JECS number will look something like A18-B13 P81 - and the Nissan number will look like 23710-68U15.
mikes94q
Car: 1994 Q45 61k
the 4E is B16 P93
the 4J is B20 P97
it a 1994 q45
mikes94q
Car: 1994 Q45 61k
i think that both are no option ecus from the 94 same engine, but I think the b20 is for a california emissions, and the b16 is federal. Not sure if this will effect anything. I got it all installed and the car now has spark but will not start. There is gas, and spark but no start????? not sure whats wrong now.. going to check the egr. I know that the cps is good.
goody90q45
Car: 1992 Infiniti Q45 (sold)
There's 8 ECU's for a 94 Q
Federal and CA, both have:
Base (no option)
Active
Traction Control
Active and Traction Control
A18-B16 P78 is for a 94 no option federal emissions
A18-B20 P82 is for a 94 no option CA emissions
I'll PM you the entire Infiniti list
goody90q45
mikes94q wrote:the 4E is B16 P93
the 4J is B20 P97
it a 1994 q45
Something's not right here. I'm reading off an ECU list from Jim Wolf Technologies compiled for making their chipped ECUs but for the Q45 it stops at 1994. There's a pattern from the progression of numbers from 90-94 and the two numbers you posted look like they could be from a 96.
If anyone would like the list (all Infiniti/Nissan) send me an email and I'll get it to you.
mikes94q
Car: 1994 Q45 61k
yeah I pulled the ecu from a 94 at a upullit yard. Not sure that it was the original or was replaced at some time. The other computer I have no idea either it was in the car when I got it.
