ECU RPM limit
turn left 240
Car: Race 1990 240 stock car 1/4 mile oval track
What is suppose to happen when 89 240 ka24e rpm hits 7000rpm/ My engine totally shuts down for approx 10 secs? ??Faulty ecu or normal.
corn322
Car: 1993 240sx
hmm.... isn't the e's rev limiter around 6400rpm?
azncorruptedo17
Car: 1991 Nissan 240sx SE
manual ecu redline at i think 6200? and i believe auto ecus top off at 6500? not sure search around 7000 is a bit too high don't you think? =X
bcar240
Car: 1993 240SX HB
I thought it was 6800 (manual). I used to have one and I know the "red line" on the tach starts at 6500, I know I have gone past it.
bcar240
Car: 1993 240SX HB
anyway, back to the orignial post, the rev limiter is harsh on these cars. I know that if you hit the rev limiter in a shift it is very likely the engine will die. And I have heard quite a few experiences where it is very hard to start after this happens. Don't know why, but I guess you are not alone...
hamsterball
Car: 1990 White Nissan 240SX Fastback
Probably cuts off fuel at like 6700RPM (on the stock tach needle)..
Anyways, I don't ever rev past 6,200RPM... the engine makes a really bad noise after like 6K.. (Even when i'm runnning i don't).
Careful man.. i don't trust these single cams..
azncorruptedo17
well it should do the fuel cut off... but the car dies out? never heard that before... but then again... why are you going 7000?
turn left 240
Touch 7000 briefly at end of straight on 1/4 mile circle track.
