ecu resetting
phil4watching
Car: 06 infiniti g35 coupe
i am about to put on test pipes and a plenum spacer. would i need to reset my ecu, if so how do i go about this
thankschris
TeflonG35
Car: 2003 G35 Sedan
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
The easy way, is to disconnect the negative battery terminal, pump your brakes a few times... reconnect the cable, and you're on your way.
I just bought a OBD2 scanner which helps also, you could clear any codes yourself, like me
phil4watching
thanks guys... so you think that i should reset it after these mods?
joe603
Car: 2014 Durango R/T
After any mod I recommend reseting the ECU. I'd just do the battery reset method...it's real easy and works 99% of the time.
phil4watching
okay thanks guys.... hey joe, you hear about nopi?
joe603
ya...sucks
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
The ECU and throttle release learning procedures are in the FAQ.
Both of them can be done in about 3 mins (if you don't screw up hehehe).
