ECU reset yields better performance?
RSG
Car: 2002 Infiniti I35
Many Max owners claim resetting the ECU will instantly give much better performance, is this true? Since the ECU is constantly variable and "learns" your driving style, why would we have to reset it manually for it to "re-learn" (assume no new mods are installed)
In addition to reset the ECU, I heard you can reset the Accelerator Pedal Release Position, Throttle Valve Closed Position as well as Idle Air Volume Learning... will these settings ever get messed up which require a reset?
Any inputs appreciated...
maxhopper
Car: 02 Maxima SE 6spd
By resetting the ECU, you are basically restoring the computer to the factory defualts. Whether this provides any performance gain, I couldn't tell you. It may feel that way, due to mods on a factory tune.
audtatious
The ECU does more than just learn your driving style. It makes adjustments based on airflow, timing, etc. In certain circumstances it may be possible to get better power from a reset, but at somepoint afterward it should go right back.
Since I've never seen a dyno prove this, I find it hard to trust. Butt dyno's simply don't count.
RSG
So there is really no reason to reset the ECU unless mods are made and you want the computer "learns" more quickly, or to clear codes? Even if you don't, the computer will eventually learn it, correct?
Why Nissan made the options to reset the Accelerator Pedal Release Position, Throttle Valve Closed Position as well as Idle Air Volume Learning?
audtatious
RSG wrote:Why Nissan made the options to reset the Accelerator Pedal Release Position, Throttle Valve Closed Position as well as Idle Air Volume Learning?
That I don't have an answer for as I've never looked into it.
Dragon_ryder
Car: 2000 Nissan Maxima
How do you reset the ECU on a 00' Maxima. I tried the way its shown on here with no luck, am I just doing it wrong?
RSG
The accelerator pedal method applies to 5th and 6th Gen, so it should work. Did you use a stop watch?
For 4th gen, I believe there is a a screw on the side of the ECU covered by a piece of tape and you turn to reset it. Another method is to disconnect the battery and leave it overnight, should be easier.
ZGadson
What's the gas pedal method?
