Ecu reset
Scruffy
Car: 2011 Infiniti M56x
I did an ecu reset on my 2011 M56 and now it won't stay running. I'm getting very little throttle response. Any help would be appreciated.
Ilya
Welcome to the forum.
How did you do the reset? Is the CEL blinking?
Scruffy
Thanks. No its not blinking. I drove the car 2 miles and it fell on its face
Ilya
How did you do the reset? Via device/OBDII port or via the manual steps?
Scruffy
I did a manual reset that was posted in this forum
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
I thought when you do the "pedal dance" aka the "Idle Air Volume Learning" procedure you were also supposed to do the:
1. "Accelerator Pedal Released Position Learning" procedure AND the
2. "Throttle Valve Closed Position Learning" procedure
See this thread: post6495635.html?hilit=idle%20relearn#p6495635 and look at 4th post down.
When I recently cleaned my throttle bodies and as far into the plenum as I could reach, I did the Idle Air Volume Learning procedure a couple of times, but my RPMs were still too high at idle. So, I did all the other steps first as described in the above post and everything went back to within factory specs.
Scruffy
Thanks I'll try those when I get off of work tonight
Scruffy
I tried everything several times and it still won't stay running
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
I'm thinking that the steps above do not apply to some of the 5.6 V8's. That thread is on the M35/45 forum. I could never get any of those reset procedures to work on my 2012 M56x. When I had the timing chain recall work done, the battery was unhooked for a week or so. This seems to be the only way I could get mine to reset. I would try and unhook the battery for a while and see if that works.
